Floating this early in readiness for Blyton 2025 to see if there is any interest in rod change gearbox builds:
22G1832
DAM2886
DAM5626
Can be fitted with standard ratio/close ratio helical gears or new straight cut gears and a final drive ratio of choice(from 2.7 through to 4.1)
Standard diff cage or x-pin.
New bearings, genuine baulks, seals, gaskets, layshaft and centre oil pick up.
I can add price to the advert for your required casing and specification.
Casings will be solvent cleaned and can be vapour blasted if required.
Can also supply transfer case, gasket and idler gear shimmed ready to fit.
Regards Jason
Rod Change Gearbox Builds 2025
For Sale Section Rules
1) This section is for advertising items that you have for sale. Not for the discussion of listed items. If you wish to debate the pro's & Con's of any item listed, please start a new topic in the appropriate section.
2) Please DO NOT post links to your ebay auctions. This section is NOT for the advertisement of your ebay auctions.
5) Items listed for sale should WHEREVER POSSIBLE* be offered with a purchase price, not asking for bids from members. If you wish to auction your item to the highest bidder I would suggest you use ebay & pay the associated fees.
6) This section is offered as a free service to enthusiasts. Any deals made are between the buyer & seller only. The MK1 forum takes no part in any transaction & the appearance of any item in this section is not a recommendation. I strongly suggest that both buyers & sellers are happy to proceed with a deal before any money or goods change hands.
7) It expected that people posting items for sale are "Active Members of this community". Any Adverts placed by members with a post count lower than 5 will be deleted.
8) The advertising of or soliciting for VIN tags, log books or any other vehicle identification documentation without it's associated vehicle is expressly forbidden. Any member breaking this rule will have his membership terminated with immediate effect.
9) If a moderator considers any postings in this section to violate either the spirit or word of these simple requests the MK1 Forum reserves the right to delete any posts without prior warning or explanation.
10) The posting of items for sale on the MK1 forum constitutes explicit acceptance of these simple rules.
11) Members posting items for sale MUST include a rough location in their profile.
It would be much appreciated if sellers could leave the sale price on adverts after the item has been sold. This acts as a good measure of current value for other sellers.
* In some cases it may not be possible for the seller to list items with a sale price. In this case, listings will be reviewed on a case by case basis by a moderator. The moderators decision will be final.
Gary Davies
(MK1-Forum)
Rev 3.0 (10.09.2024)
Gary Davies
(MK1-Forum)
