So the mini was starting fine ( everything newly built) now I have an ignition light and it won’t start when I turn the key the final part. It starts fine with the solenoid under the bonnet. Question is how do I check the switch is working and also is there anything else I should be checking?
Starter switch woes
Re: Starter switch woes
As a note, I’ve recently installed the interior light and door switches also I’ve moved the starter solenoid onto a period correct bracket
- Has thanked: 5 times
Bit of a basic approach but I'd just pull the ignition switch wires off the back of the barrel and short them together and see if it starts.
If it does then your switch is knackered. If it doesn't you need to get a volt meter out and trace
Problem solved. New bracket was over powder coated and couldn’t earth. Sorted
- Has thanked: 7 times
- Been thanked: 33 times
