Rear Hub Grease Cap
Posted: Thu Nov 07, 2024 1:05 am
I am replacing the rear wheel bearings in my 1968 Mini Traveller (yeah, it is an MK2) and have two questions about the rear hub grease cap.
1) On my car, the grease caps have a tiny hole in the center, which surprised me since grease can leak out. The reproduction grease caps available on Mini Spares do not have a hole in the center.
http://www.minispares.com/product/Classic/ATB4098.aspx
The old grease caps are in decent condition, and can be reused. However, I wonder if they should replaced with new caps that don't have the hole? To use a software term, is the hole "a feature or a bug?"
2) When I removed the old grease cap I found it was half full of grease. The bearings had plenty of grease, and it appeared a previous owner had simply filled the cap with extra grease. Should the cap be filled with grease before installing it on the hub?
Thank you,
David Schwartz
Framingham, Massachusetts
Thank you,
David Schwartz
