Hi, does anyone have a distributor drive housing for sale , I assume these are all the same , however it is for a S engine.
Distributor Drive Housing
4) Please always include your LOCATION
Rev 2.0 (10.09.2024)
Re: Distributor Drive Housing
I'm assuming you need the A series cast part, 12A1136 but not the pressed steel plate.
I believe there are two types, the one above has a groove for an o-ring seal on the outside of the body and is the most common, the other (earlier one) doesn't
If the 12A1136 is what you need then drop me a PM - I have a few spares
