Engine number ID
YORKY
Engine number ID
Post by YORKY »
Need some help to identify two NOS Gold Seal engines.
BHM 1454 and BHM 1270
Cheers Jim
Has thanked: 191 times
Been thanked: 147 times
Re: Engine number ID
Found the below list on The Mini Forum from 'Guessworks.com' which has some info which might help.
Gold Seal Engine Id:-
https://www.theminiforum.co.uk/forums/t ... ?p=2830497
GuessWorks website:-
http://www.guess-works.com/Tech/engine.htm
BHM followed by E after the numbers were also gold for Gold seal.
BHM followed by N after the numbers were black and brand new.
https://www.minispares.com/catalogues/c ... aspx?1~1~7
YORKY
Post by YORKY »
Thanks for the reply. Strange how these numbers are not mentioned.
Cheers Jim
YORKY wrote: Mon Oct 21, 2024 8:12 pm Thanks for the reply. Strange how these numbers are not mentioned.
Cheers Jim
BHM 1270 E is mentioned in the extract above but I think BHM 1454 has been cut-off in the extract posted up by Guessworks on TMF. If you contact him direct he may be able to help as his website does not seem to display the Gold Seal engine numbers, only the production engine numbers:-
