Anyone have a spare one of these....early style with the brass banjo end.
local UK postage.
Oil filter housing pipe
4) Please always include your LOCATION
Rev 2.0 (10.09.2024)
Re: Oil filter housing pipe
I have one with filter and oil temp fittings £20
- Has thanked: 6 times
- Been thanked: 11 times
If you are stuck Dermott, it is easy to make another. Just unpick the silver soldered connection on the banjo end and bend a new 3/8" (?) copper or brass pipe to suit. Flare the nut end.
I used a soft soldered joint at the banjo end and it lasted for many months on my S while I had the cooler disconnected and was replacing the filter assembly to screw-on filter spec I gave it away to someone who wanted a shiny one, a couple of months ago
