Heater rattle
DUF2 ‘65 Elf
Heater rattle
Post by DUF2 ‘65 Elf »
I have a rattle coming from my heater, it is the direction flap lever vibrating against the front plate.
Anyone else had this?
How did you resolve the issue?
I am considering a bit of heat shrink on the lever.
Has thanked: 27 times
Been thanked: 29 times
Re: Heater rattle
What sort of heater? Old metal or 68 on plastic type? Old metal one, the standard trick was to OPEN the flap, lever upwards and bend it to give it a bit more friction as I seem to remember
I think that this should be in the technical section
Been thanked: 22 times
Re: Heater rattle
On ours I dismantled it and the foam 'buffer' had simply disintegrated. I used some window draft sealing foam tape and it did the trick for us ;-)
100BUR
Location: Cumbria, The lakes, were the roads are always quiet, and the sky is nearly always blue
Re: Heater rattle
Post by 100BUR »
Did a similar type of thing
Used those sticking felt pads that stop your furniture marking the floor :)
DUF2 ‘65 Elf
Re: Heater rattle
It is the old metal heater 1965, it is not the flap that is vibrating, it is the lever that rattles in the slot.
Re: Heater rattle
Then do as I suggest. Open the flap, lever at its most extended and slightly bend it. The extra friction will stop it rattling. It's called 'the K.I.S.S. method
