Piston rings
360gts
Been thanked: 20 times
Piston rings
Post by 360gts »
Anyone have a source for a set of Std. rings for the early S pistons. AEG341.
4 ring set....Part Number R19520-STD
.047: compression rings
TECH396
Re: Piston rings
Post by TECH396 »
Standard cast Hastings are available at Amazon. I have a set here if you want measurements. Edit Just measured comp rings to be .0615
Paul H.
360gts
Re: Piston rings
Post by 360gts »
TECH396 wrote: Fri Aug 23, 2024 6:50 pm Standard cast Hastings are available at Amazon. I have a set here if you want measurements. Edit Just measured comp rings to be .0615
Comp rings for these pistons is .047"...oil 160"
This is why I am having difficulty finding them.....most suppliers have discontinued them.
TECH396
Re: Piston rings
Post by TECH396 »
I've just called Hastings and now waiting for a reply. I'll keep you posted if I hear back before someone here knows the answer. Cheers
Paul H.
360gts
Re: Piston rings
Post by 360gts »
Tried all of those guys...even Deeves...
HOWEVER< my lucky day...a NOS a set just popped up on E Bay and I snapped them up.....
Half the price they were at Mini Mania when they had them.
TECH396
Re: Piston rings
Post by TECH396 »
360gts wrote: Fri Aug 23, 2024 7:27 pm Tried all of those guys...even Deeves...
Nice.
Paul H.
NicholasUpton
Re: Piston rings
Post by NicholasUpton »
Spares Had NPR rings that are suitable. C-STN102-20
360gts
Re: Piston rings
Post by 360gts »
NicholasUpton wrote: Sun Aug 25, 2024 9:28 pm Spares Had NPR rings that are suitable.
None in Std. size.....and they are 3 rings
iain1967s
Re: Piston rings
Post by iain1967s »
360gts wrote: Sun Aug 25, 2024 11:27 pm None in Std. size.....and they are 3 rings
You can use a size over and file the ends to gap correctly. I did that to make +30 rings fit my +20 pistons.
360gts
Re: Piston rings
Post by 360gts »
iain1967s wrote: Fri Aug 30, 2024 4:34 pm
Yep, done that many times.....bit time consuming....but works in a pinch.
In this case...I did find a NOS set of std.
