Washers
Jasonking
Washers
Post by Jasonking »
Hi, is it best to not fit washers to the the rear longer head bolts when torquing down head on small block motors?
timmy201
Re: Washers
Post by timmy201 »
The rocker post plates should be all you need. No extra washers
Has thanked: 27 times
Been thanked: 29 times
Re: Washers
Agree with Tim. The plates ARE washers in all but name
GraemeC
Re: Washers
Post by GraemeC »
I don't use washers on the head nuts that are on the pedestals.
I only use one of the plates shown (not 4), in fact I generally loctite the shaft retaining screw and then don't use any plates as I've seen them deform under the head nut as they'ne not hardened.
