Upper Door trims
360gts
Been thanked: 20 times
Upper Door trims
Post by 360gts »
Has thanked: 86 times
Been thanked: 63 times
Re: Upper Door trims
Always one of the first things to be removed from any Coopers or Elf/Hornets when they were plentiful in the local scrapyards during my Saturday or Sunday morning visits back in the 1970/80's, as an essential for 'upgrading' the doors on our more basic Minis. Only the much rarer to find Mk3 Hornet/Elfs in the scrapyard had the taller ones needed to fit the Mk3 Mini doors though. :lol:
WMU 211G
Has thanked: 4 times
Post by WMU 211G »
They're available new from Minispares ;)
Always think Mk1s and Mk2 look better with them fitted, whether or not they're Coopers. Many years ago I saw a bronze yellow Mk3 S at Stanford Hall which had them, it finished off the look of the car very nicely.
1968 Mk2 Morris Cooper
WMU 211G wrote: Wed Aug 07, 2024 10:52 am They're available new from Minispares ;)
I agree the door trims should have been factory fitted to the Mk3 S but all part of the BL cost reduction I guess, so along with the standard grille it just ended up looking like a Mk3 Mini 850/1000 to most people.
I also thought the 'wrap around' stainless door frame trims fitted to Innocenti Minis were the best and much easier to fit but now hard to find and unlikely to be reproduced.
Striped shirt
Post by Striped shirt »
The MK1/2 upper frames are too short for a MK3 door.
MK3 Elf/Hornet do fit though. These are rare as most have been cut down to fit a MK1/2.
The Mk3 Elf/Hornet upper door frame trims that fit Mk3 Mini doors and are also available new from Minispares:-
http://www.minispares.com/product/Class ... |Back%20to
More info here...
'S' Upper Chrome Window Trims:-
https://mk1-forum.net/viewtopic.php?t=30924
WMU 211G
Post by WMU 211G »
mab01uk wrote: Wed Aug 07, 2024 5:46 pm
I'd forgotten that the Inno ones are different. Saw a mint pair of Inno doors with quarterlights and upper door trims for sale at Stanford Hall a couple of years ago and was tempted to buy them, I went back a bit later and they were gone. Typical!
swifty
Post by swifty »
Small world , I got a pair of innocenti door trims from stanford hall a few years ago and fitted them to my MPI
1963 austin Cooper s mk1 1071
1966 Austin Cooper s mk1 1275
1968 Austin Cooper mk2 998
1962 Morris mini super 850
Porsche 997 turbo S
Ford transit van 280s.
I am from Essex
WMU 211G
Post by WMU 211G »
swifty wrote: Thu Aug 08, 2024 3:57 pm Small world , I got a pair of innocenti door trims from stanford hall a few years ago and fitted them to my MPI
Very smart ;)
Has thanked: 27 times
Been thanked: 29 times
Yep, VERY smart. I fancy a pair on my RCSport. Are they identical to the originals..., anybody? I wonder if it would affect its ever increasing value?
These are the Innocenti door trims which fit over the frame. Always seemed a much neater design than the trims used on UK built Minis and probably easier to fit on the production line without damaging the paintwork or having all those clips to line up...
swifty
Post by swifty »
Pete I had to tweak the top corner slightly on both of them . Couldn’t say if the inno door frame would have been slightly different to a rover MPI door frame ? … Shirley
Porsche 997 turbo S
I am from Essex
WMU 211G
Post by WMU 211G »
mab01uk wrote: Thu Aug 08, 2024 8:07 pm These are the Innocenti door trims which fit over the frame. Always seemed a much neater design than the trims used on UK built Minis and probably easier to fit on the production line without damaging the paintwork or having all those clips to line up...
How are they actually fixed to the door frames...?
And are they available new anywhere...?
They are fixed to the door frames with rivets which are hidden when the door is closed, a couple can be seen on the vertical part of door frame in the photos below.
Like most unique to Innocenti Mini parts I think they are now hard to find used and probably not enough demand for anyone to reproduce new ones.
WMU 211G
Post by WMU 211G »
Thanks mab ;)
They really do finish off the look of the car nicely.
InnoCooperExport
Post by InnoCooperExport »
The Inno trims are very nice but they do require the door to be hung very precisely, a bit too far back and that trim takes all the paint off the B-pillar. You'll see quite a few Innos with scrape marks on the B-pillar from these trims. They do look great, and they're also made of stainless steel so much lower in the upkeep department too.
Arctic Circle
Post by Arctic Circle »
I wish Catmint could start fabricating Innocent door trims... Gordon, you there?
