165-10" Blockleys on a 4.5" rim
Posted: Wed Jul 31, 2024 8:55 pm
by abs
Hi all
Does anyone have a front facing picture of 165 Blockleys on a 4.5" rim, preferably an S wheel please ?
I like the look of 145`s on a 4.5" rim but I`m after a little more grip to make up for my lack of talent so the next question is am I going to notice a significant improvement over the 145`s or are they going to roll around a bit on the rim and be less responsive ?
Re: 165-10" Blockleys on a 4.5" rim
Posted: Wed Jul 31, 2024 10:40 pm
by steve1071
Here you go. Not the best picture as I had to compress it loads and the tyre was down a bit;
Posted: Thu Aug 01, 2024 6:40 am
by abs
Thanks for that, it looks more than an extra 20mm of rubber on the ground as it sits quite flat across the top of the tyre.
Posted: Thu Aug 01, 2024 9:41 am
by Peter Laidler
Remember this Abs..... That the best tyre/wheel configuration is when the tyre sidewalls are at their most upright - as in 145's on your 4.5 rims.
Posted: Thu Aug 01, 2024 5:01 pm
by abs
Thanks Peter, I was contemplating going to 165 for the next tyre change to give the rear end more grip but I may just try a tiny bit of negative camber as it`s at zero at the moment.
Posted: Thu Aug 01, 2024 9:17 pm
by SMOKE GREY
I have used the 165 when was still a prototype. Used 145 as well, I would recommend 145s with F32 R30 pressures
![😉](//cdn.jsdelivr.net/gh/twitter/twemoji@latest/assets/svg/1f609.svg)
Posted: Fri Aug 02, 2024 2:20 pm
by abs
SMOKE GREY wrote: ↑Thu Aug 01, 2024 9:17 pm
Great stuff, I`ll give that a go, thanks
Posted: Fri Aug 02, 2024 3:48 pm
by snoopy64
Interesting info on pressures … might try that Sunday on the way to Breakfast Club
