HS4 carb elbow I.D
rnp68
HS4 carb elbow I.D
Post by rnp68 »
Hi,
I have just acquired these because they may be useful one day.
Does anyone have any idea what car they were fitted to?
They fit HS4's and are correctly spaced for an MGB.
The bolts supplied with them do not fit the HS4 threads.
I think they are cast mazac as they are slightly magnetic.
Ray
timmy201
Re: HS4 carb elbow I.D
Post by timmy201 »
They could be off an earlier car with twin H4 carbs as they share the same dimensions as the HS4
H4 carbs also aren’t threaded so that would match the studs on your elbows
olddave
Post by olddave »
Photo from another site. Marina 1.8 TC.
rnp68
Post by rnp68 »
Top man, mystery solved. Ta muchly. I might have a go at making some cold air intakes with them.
