Hi all,
Do any of the main supplier sell a seatbelt fitting kit, similar to the Britax type with chromed bolts, wavy washer etc? Or is it a case of looking on eBay.
Seatbelt fitting kit
- timmy201
Re: Seatbelt fitting kit
Nearly all seatbelt bolts (including current production cars) should have the same thread which is 7/16 UNF. You should be able to use pretty much any new bolts
Some on Somerford mini page:
https://www.somerfordmini.co.uk/seat-belts
(Some of the early Britax belts did use two smaller bolts on the tunnel)
