Hi. Have a 25d distributor in my 1275gt it runs OK there's a code stamped on it 41257E. looked on different reference sights can't see that code closes I can see isn't from a bmc mini. Any ideas ?
Rob
Lucas D25 code?
- Has thanked: 59 times
- Been thanked: 15 times
Re: Lucas D25 code?
I have it as follows;-
(Dist RPM and Deg)
Below 150 RPM No Advance
400 RPM 0.75 deg
1400 RPM 6.5 Deg
2500 RPM 10 Deg
Vac starts at 3" and finishes at 10" and give 10 Deg
(Dist RPM and Deg)
400 RPM 0.75 deg
1400 RPM 6.5 Deg
2500 RPM 10 Deg
- LarryLebel
Re: Lucas D25 code?
Here's the definitive list of Lucas distributers. It has a 41257A.
https://starchak.ca/tech/pdfs/lucas.pdf
Re: Lucas D25 code?
Although it may be interesting to find out the original advance timing of a distributor, at probably 50 years old it is unlikely to give the same curve now that it would have originally.. Also unless your engine is to the original specification AND you are using the same spec fuel as original, the timing is very unlikely to be near optimum. Yes keep the original body if that is required, but it would better in my view to get it completely refurbished with a curve suitable for current fuel and the spec of the engine.
- 68&86auto
Re: Lucas D25 code?
That list should only be used as a suggestion as to what a distributor may be and only if NO other data is available. It's full of errors, they can't even get the rotation direction correct.LarryLebel wrote: ↑Fri Jun 28, 2024 4:32 am Here's the definitive list of Lucas distributers. It has a 41257A.
