What Paints Do You Use?
cobolman
Has thanked: 10 times
Post by cobolman »
Being just about to start some welding, I know that I need to get the surfaces bright and clean before I begin.
But then I read about weld-through primer. Is this a good idea?
Once a section has been welded and linished, I'm guessing the repaired area would benefit from primer. But should I use a simple primer? Primer filler? Or some other type of filler?
My current plan is for the car to be finished using cellulose paint. Should I be using a specific primer for that?
In summary: Any advice on which paints I should be using as I go through and try to patch the bodywork?
Cobolman. Conservator for:
MiNiKiN
Has thanked: 17 times
Re: What Paints Do You Use?
Post by MiNiKiN »
Weld through primer or zinc spray where you have overlaps is certainly better than nothing between the two layers.
Once welded I apply etch primer from a spray can to avoid the immediate flush rust that'll otherwise apear.
When everything is welded, ground back and panels straightened I'd apply an epoxy primer.
I have no clue about cellulose paint...
r.tec
Location: Bad Muenstereifel (D), 30km to The Ring, 80km to Francorchamps
Has thanked: 7 times
Post by r.tec »
Hi there, I used to utilize Caropax with which I had good results especially with MIG spotwelding. Caropax is not any more availlable so I tried EUROPAX which obviously superseded Caropax with equally good results.
I do not know if this paste is availlable in UK and perhaps some of UK citizens are a bit allergic against the name of the product. ;)
Has thanked: 27 times
Been thanked: 29 times
We seem to be dishing out all this good helpful advice to Cobolman. But unless we know where in the world he is, we are really urinating into the wind.
Tell us where you are Cobolman!
cobolman
Post by cobolman »
You're absolutely right about the excellent advice on here Peter and thank you to all of you.
I'm based in Devon in the south-west of the UK. Fairly close to Plymouth, in fact.
cobolman
Post by cobolman »
MiNiKiN wrote: Fri Jun 28, 2024 8:20 am Weld through primer or zinc spray where you have overlaps is certainly better than nothing between the two layers.
Great advice. Thank you!
cobolman
Post by cobolman »
r.tec wrote: Fri Jun 28, 2024 9:00 am Hi there, I used to utilize Caropax with which I had good results especially with MIG spotwelding. Caropax is not any more availlable so I tried EUROPAX which obviously superseded Caropax with equally good results.
LOL! I'm very Euro friendly so thanks for the tip!
