Sliding window frame question...
Sixty2B
Post by Sixty2B »
Does the window frame sit on some kind of mastic on the door top?
Any advice gratefully received 😃
Has thanked: 29 times
Been thanked: 30 times
Re: Sliding window frame question...
It sits in 3 or 4 1" wide (?) 'bridges' that extend between the inner and outer parts, below the window channel. You could use a bit of sealing mastic if you wanted to. But it won't do much.
Polarsilver
Has thanked: 4 times
Been thanked: 18 times
Post by Polarsilver »
i also run a light bead of Mastic to squash between the vertical edge of the lower furry slider channel & the inner vertical of the door frame area as with "repro" slider channels fitted .. i have had rain / wash water run down behind the slider channels in that small but became an issue gap area . ;)
Sixty2B
Post by Sixty2B »
Thank you.
Do you have a part number, a retailer or a picture of these bridges please.
Has thanked: 91 times
Been thanked: 67 times
Sixty2B wrote: Tue Jun 25, 2024 12:49 pm Thank you.
I think the 'bridges' Peter mentioned are actually part of the door bridging the 'water gutter' below as seen in photo above, which the window slider channel sits on. Those I have removed usually have some kind of mastic below the window slider channel where it sits on the 'bridges' and metalwork below.
1071 S
Post by 1071 S »
Be very careful to use a true mastic…. NOT something adhesive like silicone.
If the sealant is adhesive you’ll never get to replace the runners again …EVER..
Cheers, Ian
Sixty2B
Post by Sixty2B »
Thanks for the info.
I've searched everywhere for that seal cannot find them.
Any suggestions?🤔
floormanager
Post by floormanager »
I do not really understand how you're supposed to seal the chrome part to the door. I had rain water dribbling out between the two. I had to run some CT1 along the edge on the inside.
mascher
Post by mascher »
The sealing mastic I've seen in this spot is very similar to plumber's putty.
Kelley
Polarsilver
I use the panel mastic from 3M = 08568 none-hardening will not shrink .. comes in 6mm strips ( i have rolled it to become thinner for the window tracks) .. now looking at my box of this stuff it has an expiry date of 2021 .. not an issue with my remaining new unused mastic it is still good to be used... good stuff & even used some on my J40 pedal car. ;)
Exminiman
Has thanked: 21 times
Been thanked: 12 times
Post by Exminiman »
1071 S wrote: Tue Jun 25, 2024 1:15 pm Be very careful to use a true mastic…. NOT something adhesive like silicone.
Cheers, Ian
Another reason never to use silicon sealant, is it will cause rust due to its acid etch
floormanager
Polarsilver wrote: Wed Jun 26, 2024 4:29 pm I use the panel mastic from 3M = 08568 none-hardening will not shrink .. comes in 6mm strips ( i have rolled it to become thinner for the window tracks) .. now looking at my box of this stuff it has an expiry date of 2021 .. not an issue with my remaining new unused mastic it is still good to be used... good stuff & even used some on my J40 pedal car. ;)
Thanks for the tip. I'll get some.
Sixty2B
Post by Sixty2B »
Good information for the mastic, but I need the rubber seal shown in the photo.
Where can I get these from please 🙏
floormanager
Sixty2B wrote: Wed Jun 26, 2024 7:33 pm Good information for the mastic, but I need the rubber seal shown in the photo.
There's no rubber seal. The channel sits on the top of the door,on the bridges. I looked up the mini restoration book mentioned earlier, it does have some very good Haynes type photos.
https://www.somerfordmini.co.uk/haynes- ... ion-manual
They cover the entire area with mastic, Propoer mastic. They also put it on the underneath of the channel to prevent leaks.
Sixty2B
Post by Sixty2B »
Thanks Floormanager!
