cleaning and soldering copper cables
- woodypup59
- Been thanked: 13 times
I have a bullet which has pulled off a cable (a thin one - for the wipers earth).
Stripping the wire back, the copper has black tarnish and despite attempting clean to bright with abrasive, it won't solder.
Is there a decent acid flux I can use, instead of the 'grease' type flux which doesn't seem to work.
I don't want to use crimps as they look terrible.
- Has thanked: 27 times
- Been thanked: 29 times
Re: cleaning and soldering copper cables
I use one of the basic acids that you'd find in your kitchen. Bleach and oven cleaner spring to mind. I have used acid based wheel cleaner too. Insert bare end into the acid for, say, 15 seconds and it'll come out like a shiny new pin. Ready to solder.
But make sure that you rinse in a clean water and dry before you start to solder.
- woodypup59
- snoopy64
- Has thanked: 16 times
Ketchup overnight if it’s a bit more delicate/thin ..
Kevin
Kevin
- Joel Welsh 4769VU
Barring all of the above-
Ferric chloride will etch, clean, brighten and eat into copper- removing all contamination.
Wauseon, Ohio- United States
Tartan red and black
- trevorhp
Best ever for this job.mk1 wrote: ↑Fri Jun 21, 2024 7:25 am Bakers No3 Soldering fluid.
https://www.amazon.co.uk/Bakers-Solderi ... B00Y3P5JZE
And I prefer brown sauce as an alternative
KDK 320F
HDK 443E
DJJ 226H
TFD 47G
PKV 375
I x un-identified Ex-Race Cooper S Bodyshell
1 x chassis 007 1967 Cox GTM Originally from Bolton, then Swansea.
KDK 320F
HDK 443E
DJJ 226H
TFD 47G
PKV 375
Having tasted Bakers No3 on more than one occasion, I can confirm that Brown sauce certainly tastes better
Maybe you already are, but if not, use leaded solder and not the lead free stuff
Definitely old fashioned electrical leaded solder, not the sort used for plumbing. 40% lead 60% tin with flux cores is best.
