Speedo calibration
Has thanked: 66 times
Been thanked: 63 times
Speedo calibration
Trawled the tech pages and parts lists without success so far. Am calibrating a Mk2 mini speedo, marked:
4421/01-AS. 800 (revs per mile). Marked in Km/h. Cllearly a European instrument but can't find any info re internal gearing. Any of you clever blokes tell me what vehicle this instrument relates to? That way I can do the maths and gearing.
And what about the AS suffix?
Has thanked: 123 times
Been thanked: 34 times
Re: Speedo calibration
I haven't looked up the serial number Pete, but our Aussie built Big Wheel Mokes used a 800 TPK (Turns per Km) Metric Smith Speedo, those from 75 on were supplied ex-UK. I'm sure I have the internal gear tooth counts for these, just bare with me, unless someone else can stump up sooner.
<Edit: I've just looked up the S/N and these were also a 4421/11. >
timmy201
Been thanked: 19 times
Post by timmy201 »
There’s a calculator here to tell you the most appropriate speedo drive gears
Or if it’s easier 800TPK is the equivalent of 1280TPM
http://www.guess-works.com/Tech/ratioKM.htm
1071 S
Post by 1071 S »
Just to be pedantic.... You are trying to calibrate the odometer not the speedo??
The odo is gear driven, the speedo is calibrated by changing the distance between the drive and driven plates inside the instrument.
A local shop (since closed) adjusted my speedo after a change from a 3.76 diff to a 3.44 and later to a 3.1. No gear changes involved...
Cheers, Ian
timmy201
Post by timmy201 »
It makes more sense to me to change the drive gears. Sure you can calibrate the speed independently, but then the odometer won’t read correctly
1071 S
Post by 1071 S »
Of course it makes sense .... but also costs time and $$$ ...
While an incorrect speedo has the potential to cost a few $$ no one is going to fine you for travelling a few extra KMs.
And the maths aren't difficult :)
Cheers, Ian
Thanks for the info chaps and especially Spider Chris.
Tim and Ian, thanks for yours too. I've sent you a pm.
