the modern rebuild kit for the older cylinders includes a replacement plunger to convert the old 1 ring, 1 cup type rubber seals to the modern 2 ring type.
it will fit and work fine.
Also, the brake master cylinder should have the three-legged white nylon, non-return valve. This goes in the cylinder first, so sits at the bottom of the cylinder (top -when it's fitted in the car)
