What is Coopers pd2894
Posted: Mon May 27, 2024 2:59 pm
by 5portsrock
Going through some parts and came across this plastic part marked Coopers pd2894, bolt spacing 2" centres. Approx 5/16" diameter. Any ideas? Thanks
Re: What is Coopers pd2894
Posted: Mon May 27, 2024 3:40 pm
by 360gts
Looks like a breather that was fitted onto the flywheel housing on some models.
Posted: Mon May 27, 2024 5:11 pm
by Striped shirt
Austin/Morris 1300 has these, early models I belive. They then had a metal can. Not the same as the 1275GT can, but a longer can with a shorter....lower leg...thing....
Posted: Mon May 27, 2024 5:34 pm
by imack
Crankcase breather that was open to atmosphere, as used on very early Austin 1300's.
Posted: Tue May 28, 2024 6:19 am
by 5portsrock
Many thanks for the replies.
Posted: Thu May 30, 2024 2:30 pm
by Toby
These were also made in metal too, which I believe would have been an earlier model of them
Posted: Thu May 30, 2024 2:56 pm
by GraemeC
If it looking for a home, I would potentially buy it from you
Posted: Thu May 30, 2024 3:13 pm
by Toby
I might have a spare otherwise Graeme
Posted: Thu May 30, 2024 3:55 pm
by imack
Toby wrote: Thu May 30, 2024 2:30 pm These were also made in metal too, which I believe would have been an earlier model of them
Back in the mid 80's I bought a 1967 austin 1300 engine to put in my mini. It had the metal version of the breather, but I lost the top of it. (due to the engine being knackered and having massive amounts of crank case pressure). The plastic version I have now is the replacement one I bought from the local austin rover dealer at the time.
