Page 6 of 6
Re: Mini Radford De Ville comes back to life
Posted: Mon Feb 03, 2025 10:46 am
by Peter Laidler
Do you mind if I most respectfully make a small carb suggestion Herr Doktor?
Last photo, showing carbs assembled from the rear. Shows the upright strut supporting the PCvalve to the manifold (via the cable terminal). This strut is redundant as the short length of vacuum hose is sufficient to support the PCvalve unaided.
Additionally, with the strut in place it makes removing the air cleaner box impossible until the strut is removed, allowing the PCvalve to flex and the box removed......, allowing complete (?) access to the rear of the carbs and behind the engine.
Removed mine after a couple of weeks and never looked back!
Posted: Sat Feb 08, 2025 8:55 am
by Dr.Mabo
Thank you Peter for your recommendation. I think it depends on small irregularities whether the air filter box fits or not. On another Cooper S MK1 of mine, the box just fits past the PCV valve, at least if I remove the top cover first. But I have to remove that anyway to get the box out from under the scuttle panel. I never felt the need to change that.
As I'm sure I've already mentioned here and there, I'm a fan of refurbishing old things rather than buying new ones. This is also the case with the steering column cover. It has suffered somewhat over the last 50 years, at least as far as the surface is concerned. Fortunately, nothing was broken or damaged in any other way. Of course, the MK2 cowling is also available new, but the fit and details of the old originals are different or better.
You might ask yourself why an MK2 steering column is fitted in this MK1? That was also a Radford option, because the MK2 indicator stalk meant that the foot switch for the high beam could be omitted and you also got a realistic headlight flasher.
I took the traditional route to refurbish the cowling. First I cleaned it thoroughly, then wet sanded it in various stages, from 400 to 2000 grit paper, and finally made it shine again with paint cleaner. Here is a comparison. The upper half still untreated, the lower half already finished.
Posted: Sat Feb 08, 2025 10:30 am
by Ronnie
Like NEW
Posted: Sat Feb 08, 2025 1:45 pm
by InnoCooperExport
As usual, amazing.
Posted: Tue Feb 11, 2025 12:16 am
by Nevsmini
The number on the sunroof 8244 wouldn’t be the Radford Job number as that would date the conversion to mid 1966. Look out for a number on the seats, underside of the glovebox, door panels, rear 1/4 card, back of the dash, we have even found them on the back of carpets.
Posted: Thu Feb 13, 2025 11:22 am
by Dr.Mabo
Hi Nev,
thanks for pointing out the numbers. I have not found any numbers on the carpets, the seats, the door panels or even the dashboard, although I have explicitly looked for them. I could only find a number on the back of the centre console, but I couldn't decipher it completely. I read a 150 at the beginning and a 3 at the end, but I can't identify the number or sign in between. Can you recognise more from this number based on your experience? And does it make any statement about Radford Job number?
Posted: Sun Feb 16, 2025 11:16 am
by Dr.Mabo
When the Radford found its way to me, not only the attachable body parts were missing, but also everything that needed to be bolted to the front. Consequently, the MK1 Benelite grille was also missing. Originally a radiator grille cut from an extruded aluminium section, which was comparatively cheap to buy, it has been difficult to find for some years now. So you shouldn't be so picky when you come across a Benelite grille. I once bought a grill that was painted completely white. Stripping the paint off it shouldn't be a problem. However, I really cut my teeth on it. Now we know that the freely available paint strippers are no longer what they used to be. However, industrial paint stripper has also failed on the paint used.
Of course, you could have the grill sand blasted, but that would definitely destroy the possibly still intact aluminium surface. However, as I had the opportunity to buy two other Benelite grills in the meantime, I decided to dedicate myself to them.
Similar to the Broadspeed, I had to straighten the slats, remove corrosion, remove stone chips slat by slat and then polish them. And if you're already in the flow, you can also refurbish both grilles at the same time. After the final coat of paint and reassembly, they look really tasty again. I'll get back to the first grill in due course.
Posted: Sun Feb 16, 2025 11:45 pm
by Nevsmini
Being a 1967 car I would expect the job number to start with 9 or 10 unless the car was converted later in life. Switch dates would point to when it was in Radfords. You will have a mix of the cars original switches and the Radford switches. So if you pull the dates off the switches it should give you some clues. I have seen Radford dashes with two job number, where I suspect they needed to get a car out quickly so robbed a more complete dash from another car, other anomalies have been cars with different BMC colour doors to the car.
Posted: Mon Feb 17, 2025 6:17 pm
by hanlminiman
Neville. Very interesting comment, do you think the dates were based on half years from 1963? ie 2-4-6-8-10. (63.64.65.66 & 67).
Posted: Mon Feb 17, 2025 7:25 pm
by mab01uk
Dr.Mabo wrote: ↑Sun Feb 16, 2025 11:16 am
Some excellent and skillful restoration bringing those Benelite grilles back to life!
For reference: Nippy Cars can supply reproduction Benelite grilles for those who don't have the skills or an original grille!
Benelite 9 Slat Grille.
"This is an exact reproduction of the very rare early Benelite 9 slat grille as fitted to cars such as Radfords and other special builds like Broadspeeds etc, We specially extruded the aluminium section to precise specifications to build an exact copy, we then had it bright anodised by one of the leading companies in the U.K. The result is simply beautiful, We decided to do the grille in 2 options, either with or without the facility for spotlamps,
The spotlamp grille is supplied with spotlamp brackets but the lamps are NOT included but can be supplied extra,
Looks just as stunning as wallart as it does fitted to a car."
With spotlamp holes:-
https://nippycarsonline.com/product/ben ... at-grille/
Without spotlamp holes:-
https://nippycarsonline.com/product/ben ... amp-holes/
Posted: Sun Mar 09, 2025 6:54 pm
by Dr.Mabo
I continue with a few small parts and technical components. I'm always amazed at how ‘sloppy’ or at least carelessly a Radford Mini was cobbled together back then. Obviously, little or no masking was done when applying the actually classy Radford paintwork. In any case, the same can be said for the engine bay. Here you can see how the wiper motor was painted in the wine red metallic, as well as the reducers on the hose of the fresh air heater.
Fortunately, the paint stripper worked in these areas. The plastic parts look really good again. I really wanted to avoid sanding marks on the aluminium cover of the wiper motor. So the paint had to come off chemically. And fortunately that worked. I will give the motor itself a new original hammer finish in due course.
