Has anyone got any tips for attaching the MGB seat runners to Microcells and tubular subframes? Do I need some kind of half washer like this to join the lower part of the runner which has a flat surface to the tubular surface of the subframe?
https://shop.vital-parts.co.uk/tools/da ... de=WASH158
Or, should I just bolt the flat surface up and be done with it?
Attaching MGB seat runners to microcells and tubular subframes
- Ronnie
- Been thanked: 7 times
Re: Attaching MGB seat runners to microcells and tubular subframes
I would suggest using them on the bottom of the tube to spread the bolt tension, if you are not sleeving the holes.
- gs.davies
- Has thanked: 14 times
- Been thanked: 30 times
Yes that’s a thought. I was considering using a curved washer for that purpose. This was more about positively locating a flat surface against a curved one
- Been thanked: 5 times
I have done both the following.
1) Made fancy (thinish) washers with a flat side & a semi circular side these worked really well but raised the seat up by the height of the sopacer. Did look like a neat & tidy job though.
2) just bolted the runners straight on to the round tube & kept my fingers crossed.
Both methods worked admirably.
I'll leave you to guess which my preferred method is now
