850? 998? Tell me the identity of my mini
Posted: Sun Apr 07, 2024 7:37 pm
Hello
I am a mini owner living in South Korea.
I don't speak English, so please understand that I write through a translator.
I'm running a Mini that I estimate to be 1961.
Currently, the engine and gearbox are scheduled to be overhauled, and I found out before the repair, but I don't think a lot of 850 engines are repaired.
I am wondering if I should bring in 998 from Japan and swap or maintain 850.
Currently, my vehicle came through Japan, but the air conditioner was installed in Korea.
It's still hard to tell if my vehicle has an engine of 850 or 998
Can you give me some advice?
I want to import the engine from Japan, but I am currently unable to import it because I think the engine might be 998.
The difference from another mini is that the generator fixing position is located on the plug side, so it is difficult to check the fourth plug.
Would it be better to repair the 850?
Is it better to swap 998?
Can anyone else tell me what the current engine is?
I'm using hs2, but hs4 is not in the right direction, does it work if I exchange the intake manifold together?
Once again, I apologize for not being smooth because it is written through a translator.
Will all of the hs4 carburetor and intake manifold, 25d distributor kit, and other engine gaskets and gear rebuild kits be ordered and repaired? Swap 998 engines?
I'm thinking about it, but I don't know the information of my engine at the moment.
Guessing 850 is that the air conditioner is equipped in Korea and the mk1 magic wand gear is in use.
I can't find the number anywhere in the engine block.
