Stuck in reverse!
Posted: Sun Apr 07, 2024 6:45 pm
Ok, now I've got the diff bushes out thanks to the spot on help from the highly knowledgeable members of this forum, I have to confess to my real problem:
Occasionally it would be very iffy to get ot of reverse, a lot of jaggling and eventually it would come. Then a couple of weeks ok it just wouldn't come out. Slight difference, before it would get stuck in reverse and that's it, but when it jammed completely it would also get into a sort of neutral, but not across the gate. Luckily this happened when I pulled up at home and I could reverse into the garage. No problems with any other gears.
One thing that did change before the final jam, the gear stick was a bit vague and following a post on here, it was correctly identified that the pinch bolt at the gear stick end of the remote wasnt tight enough to grip.
I took the front detent ball out, disconnected the remote, tried pry bars and a mallet (!) on the linkage from above. But still stuck. So bit the bullet and pulled the engine.
Poking a long screwdriver down onto the selector fork and it slid straight out into neutral. With the remote and gearstick connected it selects all gears and comes out of reverse no problem, no sign of a jam. However I'm a bit reluctant to put it all back in the car not having identified the problem.
Someone suggested this can happen if the linkages on top the diff are loose. Is that possible? It might be my imagination but I did detect some movement in the linkages. However loosening them as a test off did lead to any binding or jamming.
Box was rebuild last year by a mini specialist and a 4 synchro remote change box.
