Twin H4 Throttle cable bracket query
rolesyboy
Post by rolesyboy »
I've a pair of H4 (not HS4) fitted to an AEG573 Mk3 S inlet manifold
Using the typical throttle cable bracket AEG349 the line is not brilliant. It fouls on the PCV take off annf the 'line' the cable follows isn't very true so it could do with a better set up.
On the Burlen 'Brian Slark' notes they mention a throttle cable bracket with adjust & swivel but I can't decipher the part number.
It looks like JS2H24BF.
Is anybody familiar with this part or know where I can source one ? I've added a picture to illustrate what I am on about
Cheers. Mark
DougR
Re: Twin H4 Throttle cable bracket query
Post by DougR »
Hi Rollesby, the bracket you are pointing to is C-AHT-1 according to my diagrams and it bolts between the two inner inlet bolts. Is this what you are looking for? Sorry if I have not understood. Cheers, Doug.
