MS Tie rod bushes fitting
Posted: Thu Nov 24, 2011 3:47 pm
by 970s
Just manage to fit the MS tie rod bushes kit, one purple and one black color bushes supplied, instruction said fit the poly purple one to the inner end?
which end is inner end, is it better to mention forward and aft / rearward to avoid confusion? excuse for my poor interpretation on the wording, but fit it wrong does make difference, any help Rich?
Re: MS Tie rod bushes fitting
Posted: Thu Nov 24, 2011 3:52 pm
by guru_1071
inner = one nearest middle of car (i.e aft)
Posted: Thu Nov 24, 2011 5:58 pm
by YMJ
Richie,
Please can you explain the recommendation for NOT using two purple jobbies. It's not completely clear on the instructions, although I did follow them implicitly, I'd like to know the reasons why.
Posted: Fri Nov 25, 2011 4:35 am
by 970s
Rich,
I am so stupid, does it mean the purple bush fits to the end ( nut side) of tie bar?
middle refer side view of car not front view,? so the blk rubber bush goes to disc/caliper side?
Should we have 2 washers at the end? 1 cup and 1 flat washer?
Dumb Al
Posted: Fri Nov 25, 2011 6:54 am
by 970s
Posted: Fri Nov 25, 2011 10:36 am
Other way round Al. Purple bush, frame, black bush, washer, nut.
Hope this helps.
Posted: Fri Nov 25, 2011 12:11 pm
by 970s
Many many thks! Mark,
My CCC project are rolling again!
Posted: Fri Nov 25, 2011 4:11 pm
by Dean
whoops must change mine round, lucky its not fitted to the car, is it not easier to put a litttle drawing on there, or make the instruction idiot proof, ha ha ha, ( then i could inderstand them better !!!!)
Posted: Fri Nov 25, 2011 4:16 pm
by Lilihip
mk1 wrote:Other way round Al. Purple bush, frame, black bush, washer, nut.
Hope this helps.
really? purple bush goes inside? damn!!
Posted: Fri Nov 25, 2011 4:28 pm
by guru_1071
Posted: Fri Nov 25, 2011 4:38 pm
Rich,
Yoo iz loozin your grip.
Posted: Fri Nov 25, 2011 8:54 pm
by 1071 S
Interesting... which bush is the hard one???? i would have thought the black one would be rubber and therefore softer - and so should go on the inside (at the back).
After getting rid of the second poly bush - I missed the lamp post by about 9" after a tie rod snapped - I've always fitted one poly and one rubber bush with the soft one inside.
The hard bush does its job (of controlling camber change) under braking as the tie rod tries to pull itself back through the bracket and increase its length. Under acceleration the rubber takes the load and you don'y really car what's going on.
If i'm doing something dumb I'd love to be enlightened???????????
Cheers, Ian
Posted: Sat Nov 26, 2011 1:14 am
by 970s
Yeah! So My fitting is correct! right Rich?
Its a good idea to have a drawing attached with instruction as description is easily misunderstood sometimes!
Do I still need the cup washers at the end?
Posted: Sat Nov 26, 2011 9:07 am
by Tim Harber
guru_1071 wrote:a bit of a 'senior' moment
Too much time on other forums methinks
http://forums.longhaircommunity.com/
Posted: Sat Dec 03, 2011 1:10 pm
by YMJ
Yes Rich...but why?
