Mk1 Door Drainage
Mar6Gor6MG6
Mk1 Door Drainage
Post by Mar6Gor6MG6 »
I have a1960 Austin Seven, I removed the door cards and found no rubber drainage tubes either side, how many in each door 1 or 2. Also can't find tube under window track to fit the rubber pipe to. Definitely not there, thanks Gordon.
Re: Mk1 Door Drainage
Early car doors drained out the rear of the door frame not through tubes.
You should see a square hole above the door catch
360gts
Been thanked: 21 times
Post by 360gts »
Mar6Gor6MG6 wrote: Sat Feb 17, 2024 12:29 pm I have a1960 Austin Seven, I removed the door cards and found no rubber drainage tubes either side, how many in each door 1 or 2. Also can't find tube under window track to fit the rubber pipe to. Definitely not there, thanks Gordon.
Gordon,
I do believe the early 59/60 cars didn't have drain tubes..
.Cheers
Catmint
Post by Catmint »
From Bill Bells excellent site
https://1959miniregister.com/variations-doors/
Mar6Gor6MG6
Thanks very much for your answers, didn't know that , even though back in the day I had early minis but never thought about that then. All we did was tear about and not do too much maintenance, thanks again anyway Gordon.
