Damper upgrade
gs.davies
Has thanked: 14 times
Been thanked: 30 times
Damper upgrade
Post by gs.davies »
When I slung my car back together last year I put the basic KYB shocks on it just to get it going.
As I may need to do some other work on the rear suspension it seems like a good time to consider changing these shocks for something a bit better.
The ride it a bit floaty at the moment and the car feels quite ‘soft’. Whilst I don’t want to rattle my teeth loose I wonder if there’s something better I could fit.
Any suggestions?
abs
Re: Damper upgrade
Post by abs »
The KYB gas a just 552018 KYB Gas self adjusting are a very good damper, firm but won`t shake your teeth out too much, there are nine speed bumps where I live :(
There are some posh dampers out there like https://www.protechshocks.co.uk/classic ... r-package/
I use the KYB gas a just on my Cooper but standard on my daily and Spax adjustable on my screamer that gets very hard use but I probably would have given the Protech ones a go if they were around at the time.
Catmint
Re: Damper upgrade
Post by Catmint »
How good are the springs Garry when you say they car was chucked together - dampers won't solve crap springs. I've found KYB to be pretty good, even on the rally car
gs.davies
Re: Damper upgrade
Post by gs.davies »
The car is on brand new MS Evo cones.
Catmint
Re: Damper upgrade
Post by Catmint »
