Hi everyone. I mounted a Speedwell Mini sport kit on my 1965 Morris Mini 850 Traveler. To clarify, this is the one with two left carburettors that I showed in the photo in a previous topic. Please can you tell me if I have to use two chokes or just one for the carburettors to work? Then If I have to mount two chokes where can I put the second one?
Many thanks, Max
Speedwell Mini sport kit chokes
- timmy201
Re: Speedwell Mini sport kit chokes
I'm currently using a similar setup with two LH bowl HS2 carbs - I've only been using the choke on one of the carbs which has been absolutely fine for cold starting.
- moita
Hi !
Existed a twin speedwell cable back then, but they are rare to come. Anyway, you would need a extra opening of the choke hole to 1/2" hole if you had one of those twin cables. Better to use as per Tim, one single choke
This is my 850 woody traveller
- Has thanked: 29 times
- Been thanked: 30 times
Twin cables. Help is at hand, compliments of dopey son. Stunt bikes used by all the kids around here use a twin cable set-up for their weird front brake system. One cable into a plastic housing and twin cables exit it. Simple to convert or adapt to twin chokes. Available from the usual bike shops.
Twin l/h carbs!!!!!! Seems a daft way to go about things to me, being a non purist at the best of times
- timmy201
Twin LH carbs is what the tuning shops did in the early 60’s before the RH carb was available. My particular set was a dealer option from one of the local mini racers who was also a BMC dealer - Peter Manton
These days the most straightforward option would be a single HS4 but some of us don’t like straightforward
- moita
And the Australian Mini 850 sports did had a nice pair with same concept as speedwell sprint kit
- timmy201
I’ve got the sports 850 type manifold on mine at the moment. It was available from two dealers as a DIY kit or as the complete car as the Sports 850
The DIY kit was similar to the early speedwell kits, where you got the manifold, linkage and one carb & the original carb was used on one side
- Has thanked: 59 times
- Been thanked: 15 times
Yes, Leyland used these on some cars that had emission controls. P/N AYA2248. I might even have one.
