I’m keen to know what route through the car, the following wires take. Can anyone advise?
1) Fuel pump
2) fuel tank sender
3) tail lights and indicator
Do they all take the same route or different? Which is it?
The route the wiring takes.
- JeremyD
- woodypup59
- Been thanked: 13 times
Re: The route the wiring takes.
All the same - over the LH door frame, along under the LH side window and into the boot. Then the pump wire goes down through the boot floor.
- JeremyD
Thanks so much woodypup. Just to be clear. It goes above the left hand door, then down the B pillar and under the left hand rear window and into the boot?
Does it start entering the frame where the wiper motor is?
- Has thanked: 29 times
- Been thanked: 30 times
Nope.......... Up the A post starting at the big hole near the wiper. Along/over the l/h door frame, just as woody says, right to the back and down the C post into the boot area
- JeremyD
