Carb linkss
Gray
Carb linkss
Post by Gray »
Have I got these links assembled upside down as this way up it is a tad hard to adjust? Should the nut be to the top with the captive bolt to the bottom?
Ronnie
Has thanked: 6 times
Been thanked: 19 times
Re: Carb linkss
Post by Ronnie »
Hi! The lever is undercut to hold the bolt head or nut and stop it turning, and flush at the other side, the way you have it installed you should be loosening the nut at the bottom. I suppose you could always turn them around and have either the nut or the bolt captive your choice ;)
PS I think they had the nuts at the top (factory) but it wont make any difference (I don't think)
