period towing eye back
WesleyB
Post by WesleyB »
Hi,
for my Austin Cooper MK1 I 1967 I look to put a towing eye on.
Not on the front (because I have it there) but on the back ?
What are the nice period options ? I don't like a sparco :roll:
Wesley
MK1 Austin Cooper 998cc 1967 Smoke Grey
http://mk1-forum.net/viewtopic.php?f=6&t=26813
timmy201
Re: period towing eye back
Post by timmy201 »
I reckon something like this would be pretty similar to any period type. I have no idea if this particular one will fit - just an example
https://www.ebay.co.uk/itm/254228621997
Or maybe something like this painted black would blend in?
https://stevestonmotorco.com/products/r ... 5370687796
Catmint
Post by Catmint »
Polarsilver
Has thanked: 4 times
Been thanked: 19 times
Post by Polarsilver »
Photo of my late brother Bryan Purves replica rear tow eye as fitted onto his own Cooper S .. sorry the item is not for sale unless you buy the actual car ;)
Tow Eye Works well as i used it the other day to pull back my reluctant to start 1275GT
Has thanked: 29 times
Been thanked: 30 times
Blimey Norman, it looks like it was made by the people that built stonehenge!
Polarsilver
Yes Peter its a proper job & no one needs a Lathe to make one 8-)
I visited Stonehenge & Woodhenge just a few weeks ago..i expect those guys back when -they would have made one if they had access to a good Welder :lol:
School History told me it was the Romans who started to make them when they started the business called SPQR ;)
Another phrase to describe, that towing eye would be described by Army recovery mechanics as '.....built like a brick shi.......er......, toilet...'
WesleyB
Post by WesleyB »
Thanks for the many reply's, I can do something with it
Before you start Wes, maybe you ought to ask whether the towing eye is an actual EYE or a circular hook, open at the top. Easier and more versatile to have a circular hook I'd say
WesleyB
Post by WesleyB »
maybe this is also good , from the DIY store :roll:
Polarsilver
Wesley .. just think about the loading that can be imposed on your Hardware Store fitting .. pleased be advised it will fail under the loading imposed during your Mini,s recovery should your car get stuck in a ditch.
To deal with the fears of Peter.. this design of tow eye was best as i know sold by the company SPQR .. it is effective as a round circle without any opening, the 4bolt fitting spreads the loading over the rear subframe in an area that was not designed to take such loading .. last thing we need is to bend the rear subframe on a recovery ..This SPQR design tow eye ..or who-ever can claim the original design ..does the job & will be easy to make & fit.
( other than if you have a rear anti-roll bar)
Exminiman
Has thanked: 21 times
Been thanked: 13 times
Post by Exminiman »
Here you go on the MK1 website , product info for SPQR range products, number 19 is the towing eye..
Nice little product for someone to remake, I would of thought
https://mk1-performance-conversions.co. ... spqr-2.pdf
WesleyB
Post by WesleyB »
End of story :lol: That is the result
harrymini
Post by harrymini »
Please remove the coating and run a seam weld around each one, looks extremely prone to failure (in my opinion)
WesleyB
Post by WesleyB »
;) I must look, because In Belgium you normally don't do anything on the subframe.
251 ENG
Post by 251 ENG »
Didn't Abingdon just weld a spring hanger to the sub frame .
A Sprite one ?
