Rockercover cap seal.
Question, where can I get the broken rubber seal from my oilcap ?
Cheers Kees
Has thanked: 29 times
Been thanked: 30 times
Re: Rockercover cap seal.
If they're not available, couldn't you cut another from a sheet of 3mm thick neoprene sheet. Won't be affected by the oil vapour.
I have also made these using a piece of 1.6mm composite Cork gasket material.
I suspect that 3mm may be a bit thick.
By some luck I discoverd that the original rubber seal on an original patrolcap will fit perfectly.
:P Kees
