RSP distributor cap
woodypup59
Been thanked: 13 times
RSP distributor cap
Post by woodypup59 »
Not quite mk 1 I know but .....
Can someone post a picture of an RSP distributor cap, showing the plug lead positions.
I thought the post for #1 plug would be at about 2 o'clock, but am not sure.
mini_surfari
Re: RSP distributor cap
Post by mini_surfari »
I shall take a picture of my 91 mainstream tonight and upload if that helps?
woodypup59
Thanks, that would be great.
timmy201
Post by timmy201 »
It’s possible to fit the distributor drive spindle at many different orientations. Theoretically you could have it out by 180 degrees, but as long as the spark plug leads are on in the right order, line up with the rotor arm and you have sufficient rotation on the distributor to set the timing it should run perfectly fine
mini_surfari
Here you go, hopefully it helps!
Cheers, Oli
woodypup59
Thanks Safari, no 1 at 2 o'clock is what i thought.
:D
