998 copper lead main bearing shells
814CWE
Post by 814CWE »
1965 998 a series
replacement shells are white metal... but
these originals are a dark grey with copper showing through,,though crank is unmarked and the shells are not scored
same bl/bmc part number on 2 sets of shells
one set white metal..one lead bronze,,
are white metal mains ok on a 998 cooper bottom end??
ivor badger
Re: 998 copper lead main bearing shells
Post by ivor badger »
brook shaw wrote:1965 998 a series
Then they are knackered.
814CWE
Post by 814CWE »
i assumed so,,but with a micrometer theres no wear present,,
dont worry im not reusing them
66S
Post by 66S »
brook shaw wrote: originals are a dark grey with copper showing through,,though crank is unmarked and the shells are not scored ??
Copper is the wearing surface, the lead skin is thin and only used as a seating agent. Bearing shells that are showing copper are not stuffed at all and can be reused if it is determined bearing clearances are within acceptable tolerance. Many shells are thrown away for no good reason.
Al
Vegard
Post by Vegard »
Al
I do indeed agree. Measure them, and if they are not scored, why not reuse?
andy1071
Post by andy1071 »
I would have thought that the copper is there to bond the 'white metal' to the steel backing, as they both bond well to copper, but not to each other.
ivor badger
andy1071 wrote:I would have thought that the copper is there to bond the 'white metal' to the steel backing, as they both bond well to copper, but not to each other.
That is exactly the point. Whatever thickness the lead indium, it means the shell has worn at least that amount to show the copper.
You never reuse shells, regardless of how good they look. They never reseat exactly and they are garunteed to score the crank.
Vegard
Post by Vegard »
I'm not cheap when it comes to engine parts, but I guess we have to agree on disagreeing on this..
66S
Post by 66S »
Me too Vegard.
Al
814CWE
Post by 814CWE »
well,after being in the motor trade many years,never heard of not re-using the original shells cos they will score and run incorrectly..
only way they will fail is incorrect assembly or dirty assembly
they are already mated to the crank pins,so shouldnt be an issue.
i fitted replacement shells ,but a double check with a micrometer showed the original vp shells (showing copper) to be actually slightly better on tolerance than the new replacements,,
pffft,,
so much for buying new stuff eh??
ivor badger
brook shaw wrote:well,after being in the motor trade many years,never heard of not re-using the original shells cos they will score and run incorrectly..
Well after many years in the motor trade, I found out very early on.
Anyway, it's a 998, why would it need super expensive shells unless you are vgoing to race it.
814CWE
Post by 814CWE »
was only saying a point that the old vandervell shells are a much better tolerance than the newer stuff readily available
:mrgreen:
ivor badger
brook shaw wrote:was only saying a point that the old vandervell shells are a much better tolerance than the newer stuff readily available
:mrgreen:
That's without doubt. Even the guys who worked in Glacier bearings Kilmarnock went and bought Vandervell shells when rebuilding their engines
Ronnie
Has thanked: 6 times
Been thanked: 19 times
Post by Ronnie »
Just to promote the argument - discussion! >>> http://www.waukbearing.com/Files/Knowle ... arings.pdf
Please continue. 8-)
814CWE
Post by 814CWE »
:mrgreen:
i love it!!!!!!!!
:lol:
vandervell shells or not,depends what brummy built your particular engine too at bmc
some die at 40k miles and some happily go round the clock,,,,regardless of service intervals..
as we say nowadays,,mass produced crap :D
