Carb Needles
tedmcedd
Carb Needles
Post by tedmcedd »
Ok... I dont know much about this stuff, My dads mk2 cooper now has a weber, so his twin HS2's are available... would these need new needles to go onto a 1275? (my 1300 ;) )
Ed
guru_1071
Re: Carb Needles
Post by guru_1071 »
ed
it would start with what it has, but the mixture would be incorrect 'somewhere' in the range.
you can faff around for ages with different needles, its great fun ;)
tedmcedd
Re: Carb Needles
Post by tedmcedd »
Yeah... sounds like fun... :roll:
My plan was to get it setup at minisport anyhows.... as long as it will run with them, then thats ok!
1071 S
Re: Carb Needles
Post by 1071 S »
Be careful. It will run as previously advised. All SU needles (of a particular family) are pretty much the same at idle.
However, if you're intending to drive it any distance to the shop I would be very wary. Knowing they came from a 998 one might expect them to run very lean in a 1275... you wouldn't want to hole a piston on the way.
Cheers, Ian
InimiaD
Re: Carb Needles
Post by InimiaD »
A non S 1275 should run ok with red (stock) springs and EB needles. According to DV. ;)
tedmcedd
Re: Carb Needles
Post by tedmcedd »
ok, well i'll take it easy and im sure minisport will advise, ive always found the rolling road there very good.
I was planning on a bigger valve head to go with the twins and the maniflow... :/
