Roller bearing drop gears
Re: Roller bearing drop gears
Mine are Straight cut, never seen helical full roller.
They were in development though i think, was it Minispares?
Caution
may contain 8 Ports, Xe's and VTec's, I don't do standard!
Caution
I saw pics of one used set about a year ago but none in real. Will dig out the pics later
Exactly. Spider do you have source where to get them?
- mk1
Please excuse me if I am stating the obvious. But doesn't it make more sense having a roller bearing helical idler gear than a straight cut one. Surely it is the side loading on these gears that is always the most important thing influencing their performance.
IIRC it was also someone on Turbominis who did that.........
Yes, the side thrust is the bigger issues I've found with helical idlers. That is a pair of Tapered Rollers with a spacer between them in those that I've done. There is though a type of Cylindrical Roller, similar to those used in the Straight Cut gears, that can take side thrust, but those I looked it were marginal for thrust loading in this application.
