front wheel toe out settings
pad4
Post by pad4 »
Hey chaps
Any one know what 1/16 toe out would be in mm and also in degrees / minutes for a 10" wheel (and whats the maths behind the conversion)
Thanks guys
Red1967
Re: front wheel toe out settings
Post by Red1967 »
Straight from the Haynes Manual
Front Wheel Alignment - 0.0625 in ( 1.58mm ) Toe out, unladen
Castor Angle - 3 degrees +/- 1 degree positive, unladen
Camber Angle 2 degrees +/- 1 degree, unladen
Swivel Hub inclination - 9 degrees 30 minutes, unladen
Hope that helps
Todd
ivor badger
Post by ivor badger »
22 minutes
Red1967
Post by Red1967 »
I guess my manual has a miss print.
ivor badger
Red1967 wrote:I guess my manual has a miss print.
No, your manual quoted the toe out in inches/mm. 22 minutes is the 1/16" diemension coverted to angular.
