Rattle in the back
Posted: Thu Apr 27, 2023 2:20 am
by nickacb
So my 60's mini was making some noises when driving around and I have been able to fix them in the past months. The thing is there is a persisting noise on the back of the mining for most part of the driving time, It has cones suspension so I don't know if the only way around it is to replace the cones or could be something more easy to fix.
Any comments apprieciated.
Nick
Re: Rattle in the back
Posted: Thu Apr 27, 2023 3:14 am
by timmy201
My rattle turned out to be a broken rear exhaust mount. It might be worth giving yours a wiggle to see if yours is ok
Posted: Thu Apr 27, 2023 10:33 am
by Andrew1967
Shock absorber bushes or even the shocks themselves ?
Posted: Thu Apr 27, 2023 11:13 am
by 111Robin
I agree with the others. The least likely culprit for a rear end rattle are the knuckles or springs. Worn knuckles will creak/squeak not rattle. It sounds stupid but you might even have a stone sitting in the bottom of the subframe, below the trumpet,, there's plenty of space for a stone to rattle around in there.
Posted: Thu Apr 27, 2023 11:22 am
by colinmac1330
I had a rattle at the back that was very annoying and it turned out to be the bottom shock mount bush.
Posted: Thu Apr 27, 2023 11:39 am
by AndyPen
Wrap an old rag around the rear trumpet you suspect and tie it on tightly / tape it up. If the rattle is muted you'll have a better idea if that is is the culprit when you you run it around the block to check.
Posted: Thu Apr 27, 2023 12:52 pm
by mab01uk
Andrew1967 wrote: Thu Apr 27, 2023 10:33 am Shock absorber bushes or even the shocks themselves ?
My rattle in the back was a top shock absorber/damper rubber bush that was worn/perished, hidden behind the petrol tank, which was allowing metal to metal contact with suspension movement.
Also but more of a buzzing sound than a loud rattle can be the chrome trim vibrating that is fitted around the top edge of the rear pockets/bins.
Posted: Tue May 02, 2023 5:07 pm
by nickacb
Thanx a lot for the recommendations, actually, I took the mini for a long highway ride (5hrs) this weekend for the first time in many years, and the noise reduced, noy entirely, but something to notice.
thanx
Posted: Fri May 05, 2023 12:11 pm
by AndyPen
nickacb wrote: Tue May 02, 2023 5:07 pm Thanx a lot for the recommendations, actually, I took the mini for a long highway ride (5hrs) this weekend for the first time in many years, and the noise reduced, noy entirely, but something to notice.
thanx
Hope nothing fell off??? ;-)
Posted: Mon May 08, 2023 4:45 pm
by nickacb
Jeje, no everything's well, but I'm looking options for a kit of shock absorbers, thanx
