distance between cylinders
Posted: Thu Mar 09, 2023 11:33 am
by baptiste
Hi
I don't have the yellow book or the technical journals
Can someone help me ?
What worth x1 x2 and x3 in mm?
I guess that x1=x2 and I have a doubt for x3 if it is longer or not.
Thanks in advance.
Re: distance between cylinders
Posted: Fri Mar 17, 2023 12:13 am
by DougR
Hi, X1 and X3 would be the same. X2 would be greater in the case of an 850/998 and smaller for large bore 1070/970/1275. I can give you exact dims if you tell me what the bores are. Cheers. Doug.
Posted: Mon Mar 20, 2023 8:56 am
by baptiste
I made a mistake while writing
if you have the dimensions, I would like to have them for the 1275
Thank's
Posted: Mon Mar 20, 2023 6:39 pm
by DougR
Hi, I checked 2 blocks. In both cases X1 and X3 are 77mm. X2 is 76.0 in one case and 76.1 in the other. I hope this helps. Doug.
Posted: Mon Mar 20, 2023 7:06 pm
by baptiste
Thank you !
yes of course i didn't have any engine here :)
Posted: Mon Mar 20, 2023 7:25 pm
by DougR
You're very welcome. If I can help with anything else, just shout. Doug.
