Couple of wiring and headlamp questions
Posted: Tue Jan 31, 2023 8:51 am
I finally received a front loom from Autosparks (after going round in circles with Adam from Wiring Harness Company…) and I took the standard loom instead of the modifications I’d spec’d with the other firm.
Loom is now largely fitted up and connected to what’s present in the engine bay, and the switch panel is done.
My car when it last ran was fitted with sealed beams, and as a stop gap until I can start improving it, I’ve got a generic set of H4 Halogen headlamps. Am I right in thinking the H4 and the sealed beams are the same power rating, which in theory overloads the switch? I don’t want to chop the loom up, nor do I really want to start making up auxiliary looms to accommodate relays for main/dipped beam.
Will the switch be ok if the ratings of the new H4 lights are the same as sealed beams? If not, I think maybe LED bulbs are the way to go. If so, has anyone got any recommendations and experience of using LED H4 bulbs in standard headlamp bowls with standard H4 headlamps?
Also, I’ve got a pair of wires terminating in bullet connectors which are coloured coded for the horn; they’re quite heavy gauge, and I presume I’ve got to make up a pigtail to join the horn to this point. Is that right? Should the gauge be the same?
I’m missing the block connectors which join front and rear looms by the wiper and join the column wiring - are these both five way isolated sleeve type?
Where does the earth loop from the centre clock area locate? Is it secured to one of the binnacle screws with a nut? Does the washer tubing run down through the parcel shelf grommet?
Finally, in the boot, is there a joint for the number plate lamp by the tank? The loom ive got just has a very long lead that is currently not terminated and needs bullets on, no joint? Should it be joined?
Gary.
Gary.
