hydrolastic displacer removal: which way is anticlockwise?
Posted: Tue Oct 18, 2011 1:09 pm
by scooperman
The Haynes manual states to rotate the front displacer anticlockwise to unlock it from the subframe. Mine will not budge. Before I apply more persuasion I though I should ask if I am trying to move it in the correct direction. I assume anticlockwise means viewed from below, could they have meant viewed from above?
Re: hydrolastic displacer removal: which way is anticlockwis
Posted: Tue Oct 18, 2011 1:31 pm
by bmcman.ie
from below, from the side, take your pick!
Posted: Tue Oct 18, 2011 4:25 pm
by guru_1071
sometimes you have to give the displacer a good whacking with a bit of wood and a hammer to free it up.
Posted: Tue Oct 18, 2011 6:48 pm
by scooperman
bmcman.ie wrote:from below, from the side, take your pick!
Let me guess, you are a technical writer for Haynes?
Posted: Tue Oct 18, 2011 7:49 pm
by IAIN
have you taken out the angled bracket ( number 65 ) on the picture.
http://www.somerford-mini.co.uk/pdfs/Ca ... lastic.pdf
Posted: Tue Oct 18, 2011 8:31 pm
by 66S
Anti-clockwise as viewed from the piston end. A filter strap around the body and a few blows from a soft hammer usually frees them.
Regards
Posted: Tue Oct 18, 2011 9:35 pm
by LMM76C
guru_1071 wrote:sometimes you have to give the displacer a good whacking with a bit of wood and a hammer to free it up.
Endorse that. Changing them in period on International rallies, I invariably found it necessary to do that, even when the displacer had only been fitted into the subframe a few days earlier.
Posted: Thu Oct 20, 2011 12:04 pm
by scooperman
First attempt was using a motorcycle piston ring compressor. This is a band-clamp like an oil filter removal tool, but instead of a lever handle the band is squeezed by a long ratcheting pliers. The band kept sliding off the displacer. I made a substitute band out of thick wire, this grabbed very tightly but would not budge the displacer. A few good whacks with a small hammer were sufficient to break the wire.
I then moved on to an oil filter band wrench, and like the ring compressor it kept slipping on the displacer. A few good whacks with a large hammer were sufficient to upset the wife but did not budge the displacer.
I then purchased a pair of vise-grip (mole-grip) pliers made to remove oil filters http://www.harborfreight.com/locking-oi ... 66568.html
One good tightening and one good whack with a huge brass mallet on the handle of the pliers got the displacer turning, a few more whacks and it was free.
I rotated it anticlockwise, looking up from beneath the displacer, to unlock it. Looking at the locking nubs on the displacer, they appear to have ramps on both ends, so if the subframe has similar tabs with entry and exit ramps then it would not matter which direction you rotate the displacer. If the subframe has tabs with a stop at one end, then it matters. Anticlockwise from beneath is all I need to know.
Next: cut away the old hose and install new fittings.
