Works Flash / Wipe switch Wipac series 183
dazibee
Post by dazibee »
http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... NA:GB:1123
I have found one of these switches in my box of Mini junk. I have checked it out with an ohm meter and it works fine. The switch is real sloppy, not precise at all. To make the switch you either push the lever up, down, sideways or even in to make the contact. Is this how they are supposed to be. It does not appear worn at all and I suspect it has never been used.
Does anybody have any info on these please?
Daz
JC T ONE
Re: Works Flash / Wipe switch Wipac series 183
Post by JC T ONE »
Daz
Sounds like a Lucas item ;)
dazibee
Post by dazibee »
No it is a Wipac series 183
JC T ONE
Post by JC T ONE »
dazibee wrote:No it is a Wipac series 183
Ahh so my little joke, was aemed at the wrong target :oops:
I have a couple of Wipac reverse lights, on my car, they work very well.
coop12g295
Post by coop12g295 »
LUCAS "the prince of darkness" what a brilliant misnomer :lol:
ORX7F
Post by ORX7F »
on works cars LUCAS flashers were used, not the Wipacs, contrary to what all ebay sellers claim. I will try to find a proper pic. They do look similar to Wipac's, but have a different rear-dash fitting, more like a small barrel, and lucar terminals. They came in 3 different lengths. Now, where is my Abingdon anorak....
JC T ONE
Post by JC T ONE »
ORX7F wrote:on works cars LUCAS flashers were used, not the Wipacs, contrary to what all ebay sellers claim. I will try to find a proper pic. They do look similar to Wipac's, but have a different rear-dash fitting, more like a small barrel, and lucar terminals. They came in 3 different lengths. Now, where is my Abingdon anorak....
That makes sence, with all the works info, as it explains how 2 (or more?) Lucas wiring specialists,
worked almost fulltime, for Abingdon/BMC/Works.
Tim
Post by Tim »
In the '50s and '60s Wipac (from Wico Pacy) components were the cheaper option over Lucas. For example, on the high end models of BSA motorbikes 'quality' Lucas components were used while the low end models used Wipac to save a few bob.
Tim
1955 BSA C11G
1961 Morris Mini Traveller
1969 Triumph TR6R
1977 Leyland Moke Californian
dazibee
Post by dazibee »
So the switch being all woolly and wobbly is normal then?
It's going on ebay later to start its new life as the basis of a dodgy Works replica Cooper S for somebody. :D At least it will make someone happy rather than stored in a box for another 35 years.
These switches do feel strangely wobbly in operation.
M.
dazibee
Post by dazibee »
That's good to know. Mines in perfect working order then.
ivor badger
Post by ivor badger »
I reckon this is the correct switch. cannot believe that a car individually wired by Lucas personel used Wipac parts.
http://www.ebay.co.uk/itm/250947677111? ... 1558.l2649
ace01
Post by ace01 »
Ronnie
Post by Ronnie »
ace01 wrote:I think this is the correct one. ;)
http://www.ebay.co.uk/itm/LUCAS-HORN-SW ... 7270538418
Thats it :!: :!:
Pete
Has thanked: 15 times
Been thanked: 38 times
Post by Pete »
Also used by Radford.
