Page 1 of 5
Actual 998 Chat about rebuilds
Posted: Sun Oct 02, 2022 6:56 pm
by snoopy64
Hi
I’m looking to have an actual chat (on the phone!) with anyone who can give me advice on getting my Cooper engine rebuilt, questions to ask the rebuilder, choosing a company etc any personal experience and the million dollar (almost) question , should I even do it?
pm me if you can help
Kevin
Re: Actually a General Chat about rebuilds
Posted: Mon Oct 03, 2022 10:57 am
by Peter Laidler
That's a good lead-in to another question that maybe Kevin might like to consider. Has anyone had any dealings with local Oxford firm OSELLI recently?
Posted: Mon Oct 03, 2022 12:13 pm
by woodypup59
Many people seem to be be happy with SMMT (Southam) who are now at Napton, nr Daventry, but before that I guess you need to know what you want.
I guess you have a 998 Copper. Do you want to keep it stock, or are you looking for a lot more power ?
Posted: Mon Oct 03, 2022 2:46 pm
by snoopy64
Just a stock short engine rebuild..
Posted: Mon Oct 03, 2022 3:07 pm
by johnv
You're in Berkshire? Bracknell Classic and Modern Engines would be a good starting point
Posted: Mon Oct 03, 2022 3:21 pm
by snoopy64
Hi there
Not the first time they’ve been mentioned..
Posted: Wed Oct 19, 2022 3:54 pm
by snoopy64
Thanks everyone for your advice etc. Well its started... is that Marmite or Bovril though??
Posted: Wed Oct 19, 2022 3:57 pm
by WMU 211G
It's space dust mate... where
exactly have you been driving it...?
Posted: Wed Oct 19, 2022 4:08 pm
I have seen MUCH worse.
Posted: Wed Oct 19, 2022 4:44 pm
by Roadrunner
Peter Laidler wrote: ↑Mon Oct 03, 2022 10:57 am
Your having a laugh there, I only ever used them for machining ie re-bore and balancing I preferred to build my own. I did then Richard Walker worth using though he used to work there before setting up on his own but I see now his company was purchased by some one else. Last engine I built I got as a kit from MED only because I happened to be working nearby. Osselli was an Oxford Based Firm that was in Eyensham when I first went there then moved to Osney Mead. It's not in Oxford any more.
I just looked at the manual when I did my first rebuild and I can send a PDF of it if you need one.
Posted: Wed Oct 19, 2022 5:02 pm
by snoopy64
WMU 211G wrote: ↑Wed Oct 19, 2022 3:57 pm
The previous owner ruined it, thought he was driving a train
Posted: Wed Oct 19, 2022 5:59 pm
by Roadrunner
As you have West Berks where you come from you could have a word with
https://h-dev.co.uk/ for some advice not they look to me mainly remapping though but they are at Chieveley
Posted: Wed Oct 19, 2022 6:11 pm
by Peter Laidler
Are you saying (previous page) that Oselli are crap - or that you are better - or what exactly......?
Posted: Wed Oct 19, 2022 6:43 pm
by snoopy64
mk1 wrote: ↑Wed Oct 19, 2022 4:08 pm
Thank goodness, I think!!
by Roadrunner
Peter Laidler wrote: ↑Wed Oct 19, 2022 6:11 pm
No when I was younger I heard some bad vibes about them and building an engine yourself is easy enough if you have the gear or knowledge. One of my friends had his S engine rebuilt by them and it ran OK but they are not the old firm I knew when it was in Osney and I worked round the corner. I would not put them down I'm sure a lot of people are happy with the work they do but you will always find problems. I must admit the work they did for me when I had a problem with a gearbox in my GT was spot on. What I meant are having a laugh is I did not think they were still operating seems they are
Posted: Wed Oct 19, 2022 6:46 pm
by WMU 211G
snoopy64 wrote: ↑Wed Oct 19, 2022 5:02 pm
Notch eight, don't be late...!
Just bore the blighter out to 1380 and have done with it Kev!
Posted: Wed Oct 19, 2022 6:51 pm
by 251 ENG
Southam mini metro centre SMMC 01926 815681
BUT
Got 40+ engines in a moment so be prepared to join que
Biggest problem with 998 cooper is D top piston availability, new oversize ones are incredibly rare .
You can use flat top pistons but that means you have to take a big chunk off head .
You can also modify flat top pistons to D tops but then you have to take a chunk off block
Posted: Wed Oct 19, 2022 7:19 pm
by snoopy64
Plenty to think about…
Posted: Wed Oct 19, 2022 7:21 pm
by hanlminiman
Sent you a pm.
Cliff
Posted: Thu Oct 20, 2022 8:53 am
Can't get much better than those Compression readings!
