Is there a video of installing the upper door trim? Orrrrrr, a relatively simple
set of instructions? Thanks
Kent
Installing stainless upper door trim
- 65MK1S
- TECH396
Re: Installing stainless upper door trim
The trim should first slide down over the 3:vertical retaining clips at the rear of the door, and then slide over the one forward / lower clip. ( These are the thin flat clips)
The remaining 6 are domed and the trim will snap on with a bit of persuasion. ( Best to start these ones by twisting the trim to fit one side of each clip at a time)There are 4 of the flat style and 6 of the rounded style per door. I've heard that some aftermarket retaining clips don't work.
Paul H.
- 65MK1S
