Purolator oil filter housing
Posted: Wed Mar 09, 2022 9:16 pm
by Brett
On my 1967 Austin Cooper, I have this Purolator oil filter housing, with pressure switch for warning light. Part number 37H1528. This part is no longer available.
My engine is being rebuilt and the rubber seems to be damaged. What would you do?
I want to stay as close as possible from original.
Thanks for your help.
Re: Purolator oil filter housing
Posted: Thu Mar 10, 2022 7:10 am
by Fanfaniracing
Someone has thinking something when welding the pressure release ball.
I do this on every bulild.
Imagine your Filter is blocked, the valve opens and all the Dirt goes directly to your Bearings...
Posted: Thu Mar 10, 2022 8:07 am
by r.tec
...but imagine filter is blocked and no oil gets to the bearings. What will happen then? Crank? Perhaps conrods? Bearings gone in any case within half a minute...
Posted: Thu Mar 10, 2022 9:13 am
by Peter Laidler
Scrape away one or two of the staked retainers and you will be able to hook out the plate that retains the seal. Strip spring etc out carefully, clean and inspect, re-seat and test. Simple to test using a continuity meter while you press in the rubber tit with the end of a pencil. Just re-stake and you're home and dry.
Are you sure that there shouldn't be a large diameter circular plate attached, on TOP of all of this stuff too?
My 69 S has the tab but the wiring it taped back into the loom - with a little note stuck into the user handbook to this effect
Posted: Thu Mar 10, 2022 10:30 am
by STG95F
As Peter said should have a plate over this seal/ plunger
Posted: Thu Mar 10, 2022 10:41 am
by Fanfaniracing
r.tec wrote: Thu Mar 10, 2022 8:07 am ...but imagine filter is blocked and no oil gets to the bearings. What will happen then? Crank? Perhaps conrods? Bearings gone in any case within half a minute...
That's why you have a Gauge and or a warning light
Posted: Thu Mar 10, 2022 2:32 pm
by Brett
STG95F wrote: Thu Mar 10, 2022 10:30 am As Peter said should have a plate over this seal/ plunger
Yes, I have the plate. ;)
Posted: Thu Mar 10, 2022 2:33 pm
by Brett
Peter Laidler wrote: Thu Mar 10, 2022 9:13 am Scrape away one or two of the staked retainers and you will be able to hook out the plate that retains the seal. Strip spring etc out carefully, clean and inspect, re-seat and test. Simple to test using a continuity meter while you press in the rubber tit with the end of a pencil. Just re-stake and you're home and dry.
Will do that. Thanks.
Posted: Thu Mar 10, 2022 2:44 pm
by Peter Laidler
While we're on the subject, can anyone in forumland explain why the latter Mk2 Coopers and S's had the purple and white wire to the filter head tucked back into the loom. Together with the little explanatory notr stuck in the user handbook. Just out of interest
