Lockheed Servo Identification
- 111Robin
- Been thanked: 17 times
Does anyone have any AP Lockheed data that could help identify this servo ?. The tag number is 4257 818 10 and L17C. I have contacted Seltech who are now the AP Lockheed supplier but they haven't come back with anything.
- Has thanked: 4 times
- Been thanked: 9 times
Re: Lockheed Servo Identification
Do you have any pictures of the casting etc? I believe you can tell different bore servos based on a ring that may or may not be on the "nose" of the body. I thought this info was on the Mk1-Perfomance Conversions main site but I can't seem to find it at the minute.
S Type 5 1/2 servos have no ring. One, two or three rings denote larger bore sizes.
I’ll check my Lockheed books to see if I can ID that particular one and advise ring ID / bore.
- 111Robin
The correct item for the car (Elan +2) according to the AP document I have is LR18221. This doesn't tie in with any of the tag numbers.
- 111Robin
Cooper S application :
- Simon776
It is a Type 6 servo from a Lockheed Brakemaster Powerbrake aftermarket kit for passenger cars and light vans with a single line braking system.
- 111Robin
It is, it is fitted to my Elan +2, replacing the original Girling unit, but I am trying to confirm if it is the correct unit for the car as none of the numbers on the tag match anything in the Type 6 fitting guide.
