Standard rad mount to S Spec
Posted: Tue Nov 23, 2021 7:52 pm
by Dr S
Hmm. Supercharger pulley in the way. Guess I need to be S spec to clear it. Is it a job that can be fabbed up at home ? Or is it just order the bits and get on with it? Back in the day would an s spec shroud have been an easy find? Or is a home brew job more in keeping?
Re: Standard rad mount to S Spec
Posted: Tue Nov 23, 2021 8:26 pm
by 1071bob
If your lower shroud is ok you can covert it to S spec by changing the lower bracket. You'll need to find a 'double bend' connecting bracket to suit or you can bend the standard one to suit.
I have a couple of the shroud brackets but no connecting bracket.
Posted: Wed Nov 24, 2021 10:38 pm
by Daz1968
I modified mine with one of these brackets, then bent my standard lower mount bracket as per pic above and worked fine, much easier than sourcing correct parts.
Posted: Thu Nov 25, 2021 9:53 am
by Peter Laidler
Where do you get this new S type lower shroud part? Or have I got to fabricate one?
Posted: Thu Nov 25, 2021 12:18 pm
by Dr S
I’ve taken the lazy option and just ordered it all up from minispares. 7ent seem to sell the weld on bracket.
Posted: Thu Nov 25, 2021 2:09 pm
by 1071bob
The 7ent USA ones are from me ;)
