Rear Seat base trim
Rear Seat base trim
Moved from another thread.
A membe is looking for the trim that goes at the base of the rear seat.
Not to derail/pollute Doc's excellent thread. I could do that, but the profile isn't quite the same. The front lip is longer than the rear, and curves forward slightly at the bottom. So says the Inno parts book.
Re: Rear Seat base trim
There is no decent pic in the UK parts list, but the trim used is just plain grey plastic in a "U" shape. Same as is fitted to the sharp edges on the inside top of the doors.
InnoCooperExport
Post by InnoCooperExport »
Thanks for moving it Mark. Hopefully someone has an idea. I have some simple non fluted arch trim that will do the job until I get my hands on the proper item.
FYI the Inno Manual lists it as AXE 383 - Finisher. Not a great help maybe.
Dr.Mabo
Post by Dr.Mabo »
mk1 wrote: Tue Nov 23, 2021 9:48 am A membe is looking for the trim that goes at the base of the rear seat.
Thanks Mark, thats a good idea.
so long
the Doc
My previous project:
Cammsjb
Post by Cammsjb »
If it's the grey trim that fits along the front edge of the rear seat pan, the part number is 24A1276, google the part number and there are a few suppliers that stock the item.
Or you can buy it by the meter from Car Builder Solutions.
InnoCooperExport
Thanks for the UK part number folks, that's a huge help. Now I can actually find it!
I don't think the stuff above is like the drawing you posted though. Its just grey PVC with even sides.
Like this:
https://www.ebay.co.uk/itm/303334756572 ... suEALw_wcB
InnoCooperExport
Searching the part number give me this one from 7ent in the US, which is less than ideal, but at least there is a picture. I thought it looked like it had a little lip at the bottom on one side, but now I'm not sure...
That looks like the closest I have seen. Assuming the picture is accurate.
