Page 1 of 2
Hydro pipes
Posted: Wed Oct 20, 2021 5:07 pm
by whistler
So, I've come to the fitting of the pre shaped hydro pipes which I collected from m-machine.........the RH side one doesn't fit. The back fits under and around the rear subframe but the front end is all twisted and pointing to outer space. So disappointed with these. Rather than try and straighten/re bend the RH one and risk crimping a corner I was thinking of using a John Guess Speedfit equal connector after cutting the little rascal and rotating it a little. I see that the 2 piece pipe from Bullmotif includes a similar speedfit connector. Has anyone tried this with Kunifer pipe? Was it a success?
Re: Hydro pipes
Posted: Wed Oct 20, 2021 7:13 pm
by Nick W
Hi Whistler
When I fitted repro hydro pipes, I cable tied them together adjusting them to match the original profile, I managed to do it without any kinks. I wouldn't really want to put a joint in a new pipe.
Here is the thread
https://mk1-forum.net/viewtopic.php?f=31&t=24633
NIck
Re: Hydro pipes
by AndyPen
If it is any help I’ve not fitted my NOS set of pipes to our 66 yet, so you would be welcome to pop up the road and have a nose?
Re: Hydro pipes
Posted: Wed Oct 20, 2021 7:31 pm
by Peter Laidler
Before you start any bending Whistler, please contact me. I've got a pipe bender just made for hydro pipes. And used together with Nick W's idea, it'll work a treat. Regards, Peter
Re: Hydro pipes
Posted: Thu Oct 21, 2021 9:51 am
by whistler
Nick W wrote: ↑Wed Oct 20, 2021 7:13 pm
Hi Whistler
Here is the thread
NIck
Thanks for that Nick. The old pipes fell off during shell stripping so no pattern but your link is very helpful.
Vaughan.
Re: Hydro pipes
by whistler
AndyPen wrote: ↑Wed Oct 20, 2021 7:13 pm
Where are you?
Re: Hydro pipes
Posted: Thu Oct 21, 2021 10:10 am
by whistler
It's the lower pipe. It needs rotating (twisting) and the bend to go up the bulkhead straightened and re bent. All without kinking.
Re: Hydro pipes
Posted: Thu Oct 21, 2021 10:16 am
by Nick W
The trick is to manipulate it , but not on the existing sharp bends. Just spread the bends in to the straight area, bit at a time, should be able to get it near enough.
They will never be perfect, but when it's all built up they usually look fine.
Re: Hydro pipes
Posted: Thu Oct 21, 2021 12:59 pm
by whistler
whistler wrote: ↑Thu Oct 21, 2021 9:51 am
Where are you?
It's OK Andypen. I've spoken to Peter and Nick has given some good advice so I'm having a go at 'manipulation' to modify the bad pipe.
Re: Hydro pipes
Posted: Thu Oct 21, 2021 1:13 pm
by Andrew1967
I had to massage the pipes into shape as well, not as bad as your one but doing as Nick suggests, you will get there.
Remember that the pipe will work harden so bends are more difficult to further bend than straight sections.
Re: Hydro pipes
Posted: Thu Oct 21, 2021 2:59 pm
by AndyPen
whistler wrote: ↑Thu Oct 21, 2021 12:59 pm
Where are you?
Sorry just logged on - I’m only up in Swansea. My car came from where you worked I think
Re: Hydro pipes
Posted: Thu Oct 21, 2021 3:25 pm
by whistler
City Motors, Cardiff.
Re: Hydro pipes
Posted: Thu Oct 21, 2021 5:41 pm
by surfblue63
Andrew1967 wrote: ↑Thu Oct 21, 2021 1:13 pm
I had to massage the pipes into shape as well...
There's a double entendre just waiting to happen
Re: Hydro pipes
Posted: Thu Oct 21, 2021 5:59 pm
by Andrew1967
surfblue63 wrote: ↑Thu Oct 21, 2021 5:41 pm
Go on Stu, I know you're dying to ..
Re: Hydro pipes
Posted: Fri Oct 22, 2021 11:31 am
by AndyPen
Andrew1967 wrote: ↑Thu Oct 21, 2021 5:59 pm
He he, I am watching the thread with greater interest now
Yep Whistler, my '64 car came from there
Re: Hydro pipes
Posted: Fri Oct 22, 2021 2:34 pm
by Allen Brzeczek
Fitted a complete set of hydrolastic pipes some years ago, cannot remember that they caused me any problem however I have since successfully used the soft copper pipe kit to repair/bypass leaks behind the rear subframe.
I did not like the look of or feel I could trust the plastic push fit connectors and suspect that they were for 8mm tube. Original pipes were 5/16" (7.93mm) and therefore opted for correct size 5/16" quality brass compression fittings from Wade. These fitted without any problem and have been trouble free since
Re: Hydro pipes
Posted: Fri Oct 22, 2021 2:48 pm
by surfblue63
AndyPen wrote: ↑Fri Oct 22, 2021 11:31 am
Andrew wrote enough in his original post to cover it.
Re: Hydro pipes
Posted: Fri Oct 22, 2021 3:56 pm
I have fitted 2 sets of these in fairly recent times. Both sets had "their issues". The first time I cut the end & shortened them by about 3" to make them fit in thge area you are having issues with. It was perfectly successful, all be it a bit of a faff.
Second time I had spoken to Nick who described how he "manipulated" them to make them fit & this was very successful. Not a quick job, but one well done.
Re: Hydro pipes
Posted: Fri Oct 22, 2021 5:01 pm
by whistler
Thanks to all. I have 'manipulated' the front end with the help of a Lidls 10mm bender and a useful bit of 2 x 1. All good now, at least until I can flip the shell the right way up and sort out the connections to the bulkhead plates. That's for another day.
Re: Hydro pipes
Posted: Sat Oct 23, 2021 2:59 am
by winabbey
Has anyone gone back to M-Machine to tell them their product doesn't fit?
